Mechanical Pump Pressure Drop at WOT?
carnutjw
622
1,470
78Delta88
1,303
1,096
SW Arizona
I remember from before and you found the pump for the 454. Could be just weak pump or partial blockage. I seriously doubt it has anything to do with the pump rod or eccentric.
bracketchev1221
1,421
1,665
I don't know how accurate that calculator is. I can tell you for a fact a 1000 hp race engine is not getting by on a 75 GPH pump like that calculator says. There is acceleration forces pushing the gas back to the tank that the pump has to overcome. I would think there is a correction factor that yes maybe on a stand at rpm it may use less fuel but in a car I think it needs a lot more. Overall, dropping 6 to 4 psi at wide open throttle is not terrible but it showing the system is limited. My dad used to cross the finish line at 3 psi with his race car back in the 80's. He claimed as long as it had pressure there was gas in the bowl.
86 Salon
Mar 14, 2021
72
80
While there may be an issue with the fuel pressure dropping at higher speeds, if it's enough to keep the float bowl full, it probably will not cause any issues. I would still check all hoses and clamps for any damage because you may have issues down the road. If it was fuel injected, low fuel pressure would be a problem.
78Delta88
1,303
1,096
SW Arizona
Another good reason for an A/F meter. If at WOT the meter shows going lean, going out of normal limits, that's bad. Going too lean at WOT is a nice precursor to engine damage.
Going somewhat lean at cruise helps increase MPG. Lean at wide open is bad, not good.
If your FP reduces to 4 psi, but not going lean, then it's something to improve on but not stress over. If it's going lean then the obvious is to resolve it as soon as you can.
