For my Monte I just wired in the 2 micro switches and then locked the column in park, since I have a full manual valve body and have to constantly shift to each gear I did not want anything but the cable connected to my shifter linkage.
My Tanny is a full manual valve body I just put the B&M trans park shift kitFor my Monte I just wired in the 2 micro switches and then locked the column in park, since I have a full manual valve body and have to constantly shift to each gear I did not want anything but the cable connected to my shifter linkage.
Yes I bought a console and shifter plate from Dixie Restoration Depot
Wow that looks good the shifter are closeNot sure how the Mega mounts compared to a Quicksilver but take a look at this page. Look at the attachments. The measurements are at the bottom of the page. The shifter fits well in the console.
83 SS bench to bucket and column to console questions...
This is what I put in my 81. I used a B&M shifter. The seat and console mounts came from Mikes Montes. The bracket for the shifter is homemade. The hardest part was getting someone over to weld them all in. Mikester if you don’t mind me asking what are the measurements of the...gbodyforum.com
View attachment 126017View attachment 126018
If I recall, you would actually retain the bracket that connects the backdrive rod to the selector shaft on the transmission. Then you would add the lever that comes with the shifter and attach the shift cable to that. ..if that makes sense to you. Doing it that way retains the use of the stock reverse light and neutral safety switch. No wires to cut and splice. You might have to run a lead for the shift indicator light...if supplied, of course.Ok I see, so any ideas of how I would set up the shifter with stock backdrive?
Mich,Jack, after pulling whats left of my hair out with that stupid shifter I wound up buying a relay for the neutral safety. Do you remember how you wired it ? I thought I had the right plug but it wouldnt stop the car from turning over no matter how I ran the two wires.
