Thanks for that information. It certainly opens up another option. But, is it worth acquiring the tools, and will it be a continued problem with seals going periodically?
Doug,FYI…It a general consensus that R4 compressors are junk from the factory. Another GM failure. They leak Freon and sling oil everywhere. Look at the bottom of your hood at the compressor location and you’ll see an oil stain. I ran them for years with Oldsmobile engines. It was painfull to replace hood felt, oil and freon every few years. Now I run an LS with a Sanden compressor.
Since getting sick I haven’t gotten around to replacing the condenser, lines and hooking everything up. Part of the problem has been sourcing a cross flow condenser. I’m tempted to take it somewhere to make it right but I don’t like other people working on my stuff.Doug,
Does the Sanden compressor use the same PAG oil as the stock R4 equipped system?
Doug,
So, if I do decide to go with the Sanden setup, it will certainly entail completely flushing the system.An R4 uses PAG 150 a much higher viscosity oil than the PAG 15 that the Sanden uses.
I figured it would involve having to flush the system entirely. Thanks for your feedback, Jake.R4 in the old days used mineral oil
R134 uses synthetic oils, some synthetics are backwards compatible, but mineral oil is not forward compatible.
If you reuse the stock evaporator and condensor and lines and swap to r134 it's a decent idea to get as much of the old oil out as possible.
The anal AC people will tell you to swap EVERYTHING from R12 to R134 but 99% of the time it's fine. If the old part blows up who cares, you would have replaced it anyways.
Yes, you will have to change the receiver drier and flush the rest. that's the beauty of the old system it is easily flushed. Modern condensers often cannot be flushed properly you have to replace them.So, if I do decide to go with the Sanden setup, it will certainly entail completely flushing the system.
Thank you, I appreciate all the useful information. My system currently is still fairly new. Brand new AC Delco compressor, new condenser, evaporator, drier, liquid line and hoses, etc. I'm thinking it might be cost effective to replace the seal in my compressor and try to get a few more years out of it.Yes, you will have to change the receiver drier and flush the rest. that's the beauty of the old system it is easily flushed. Modern condensers often cannot be flushed properly you have to replace them.
