you can't use the ls style compressors. G-body units kick the compressor into on & off cycles, where the new compressors have variable internals. These compressors will work for a while with g-body controls, but WILL eventually fail. Wish I had known that earlier with my LS swap done back in 2002'.
FWIW in case someone else is looking at swapping over to a newer compressor as part of an engine swap:
Newer AC compressors use variable displacement compressors so they can modulate how much volume they're pushing and don't need to cycle because of it.
G-body's use one low side switch to control the AC but newer engines also have a high side sensor to see how much pressure the compressor has built up. The only thing the HVAC controls in the car do for AC is to kick on the AC compressor since they are wired to the low pressure switch and then to the compressor. In a swap you would just rewire this to instead go to the AC request pin on the PCM and it would decide if it can turn it on or not based on what the engine is doing and what the pressure in the line is.
You can make it run like it would have from the factory by adding the high side pressure sensor, I'm doing that in my GP but with a V5 compressor and this fitting on the high side on the condensor:
This is a #6 (3/8") Female Oring to #6 (3/8") Male Insert Oring Inline adapter with 10mm switch port. The 10mm switch port is ideal for metric switches or transducers.
coldhose.com
I had a really hard time finding an adapter/fitting like that but I'm glad I did.
I am also still running the low side switch too though so it won't kick on unless the PCM tells it to and the low side switch is closed too. Been running great so far for the last 2 years
