Modified carb now can't get to run correctly
crotchss
314
61
48
Kearney, Nebraska
Hey guys, thought I would ask you all to see if someone can help me fix a problem. So I had a Holley 3310-S carb, which is a 750 cfm with a vacuum secondary. Years back I changed out the main body to a Proform brand one and also changed out secondary metering plate to metering block. It ran perfectly on my hopped up 355 SBC back then with no jetting or other changes. After that I had it on my SS for years and it performed flawlessly. I switched to a SMI 850 DP after I upgraded my 406 and needed more fuel. My buddy bought the carb off of me to put on his 406 SBC S-10. Earlier this year the baseplate cracked. So we put on a Proform billet baseplate and have been having major issues ever since. First of all, the mixtures screws used to be 1 to 1 1/2 turns out now they have to be 3 1/2 turns out to keep it running and when revved it returns to idle very slowly.If you stick a paper clip down both idle air bleeds it picks up rpm at idle. This to me indicates there is a vacuum leak somewhere, but I have sprayed all around the carb with carb cleaner with no rpm change. Secondly, at 6000 rpm exactly the motor just lays down. We have checked to make sure it isn't valve float by changing to a 770 Street Avenger carb another buddy had. Engine is way more responsive and feels like you just picked up 50hp and revs beyond 6000 rpm easily. I have disassembled the carb a number of times and the only thing I could find was one screw hole on the quick change vacuum secondary pod had stripped out and was causing a leak, so I changed the pod. Helped it out a little bit, but there is still a major issue somewhere. I have cleaned all passages and such checking for obstructions...found nothing. I have used new gaskets in it and also new carb to intake gasket. I don't know what else to look for and check. Any suggestions guys?
Yep, measured throttle bores and compared to the old one which I have saved. Both main body and plate are from Proform and both are for 750 vacuum secondary. Have run the engine with all ports plugged... no change. The only real difference I see between the two baseplates is the fact that on the old plate there is a curved "passage" cut on either side of the top of the plate that connects and balances, I believe, primary and secondary some how. IDK for sure maybe I'm wrong. Whereas the billet plate has no such "passage". Also the idle discharge holes are slightly larger on the Proform plate
http://i256.photobucket.com/albums/hh165/Banzai_Jimmy/Holley SA 770/IMG_1377_marked.jpg. Original base plate image
http://temp.corvetteforum.net/c3/themoneypit//base_plate-2_830.jpg Proform base image
Anyone know what the curved passages to the outside of the throttle blades are for? And if them not being on the billet plate matters?
that's why i mentioned to design notes....we don't know what the purpose is of each hole
Oh ok gotcha
If I were you I'd send the two pictures along with the issues you are having to Proform and see if they have the answer. If this is the right base for the carb then you would not be the first with issues. ( I mean with the carb)
Looking around on the web found out the "passages" are to connect primary to secondary idle circuit vacuum together. If each side was divide between it would isolate the front and back for 4 corner idle adjustment.
Called Proform and they tried to tell me I was using the wrong baseplate/main body gasket. I told them which one I was using and the gasket bore measurements and how I had matched up new gasket to old. After that they said they didn't know but to "tune on it". LOL. OK?
I can't stand companies who do not have technical support for their products. If they don't know what they are selling how are we supposed to figure it out
