Monte Carlo Breadbox - Switch and gauge ideas. - Complete
mikester
2,921
3,687
Small town NY
Mine is just sitting. Kinda glad I didnt put it in a month ago. LOL
mikester
2,921
3,687
Small town NY
Well, this is what Ive got so far. My first attempt. I bought the radio mount and a piece of textured plastic off of ebay. Not a big investment, under $20. Got the volt gauge from Pep Boys (thanks to Turna for the info)) for $43 out the door. The hardest thing to find locally was a 2 1/16" hole saw but I found a hardware store 35 minutes away that had one in stock.
I was able to cut the textured plastic on my table saw. One thing I realized after making the first cut is the grain on the plastic has a direction. I think it looks better having the grain go horizontally than vertically but thats just personal taste.
Got the holes cut out but I had to egg them out a little with a Dremel so the angled rings would work. I also had to open the radio mount a little so the gauges would be able to tilt up.
Now comes the problem. Piss poor planning on my part. I cut the sides on the mount a tiny bit too wide and I think I cut the angle on the plastic a little too much. I dont have enough meat on the mount to get a couple of screws on the bottom. Its a learning experience.
Im going to reorder another mount tonight. Theyre under $10. At least I'll know where to stop next time ! LMAO
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
came out good!
565bbchevy
9,614
12,683
Michigan
When I made mine I used Lexan as the face and cut the 3 holes undersize then I glued the angle rings in place.
Once the rings cured I used my flexshaft Dremel with sanding bands and opened the holes from the backside at the correct angle and size needed for the gauges.
Hope this helps.
mikester
2,921
3,687
Small town NY
Hope this helps.
Curious, what did you use for glue ? And did the rings go right to the top and bottom edge of the face ? Never thought about gluing the rings but its a great idea. Keeps them in the right position.
I cut the holes for the gauges after I cut the plastic to fit. Then I cut down the bottom lip of the mount opening by about 1/8" with a Dremel drum sander.
Like I said, piss poor planning. I think I have the side angles right but theres not enough left at the bottom of the sides on the mount for a screw.
565bbchevy
9,614
12,683
Michigan
I think I used a plastic epoxy cement and roughed up both surfaces prior to gluing and then sanded around the edges before painting to make them blend into the face better.
mikester
2,921
3,687
Small town NY
Im assuming you used small sheet metal screws on the corners ? I was going to use 6-32 button head machine screws but then I figured out I wouldnt have access to the nuts. What did you use to hold it all to the bottom of the dash ?
565bbchevy
9,614
12,683
Michigan
For the faceplate I used a coarse thread screw,(not quite a wood screw) I was going to use Rivnuts but the thickness would have pushed the face out slightly and I would have had to cut into the backside of the face for it to sit flush.
I used long hex head sheet metal screws to mount the unit to the dash since they have to go through the vinyl before hitting metal on the front and part way down the sides.
You probably did this but drill the faceplate holes large enough so that your screw threads don't engage it.
mikester
2,921
3,687
Small town NY
I considered using some marine epoxy to glue a small strip of aluminum to each side. Drill the four holes, tap them and use a small machine screw. I might play around with it tomorrow. I still ordered another mount. Its only $9.
Since I have another one coming I think I might trim the front mounting strip back a little too. I have a few days to try different things. It looks like you would only use mounting screws on the sides and not the front.
