Moroni sticker
I did a little piddling with a chevy format and yanked off codes from your SPID. I didn't have a dealer code, order number, or dealer address. Plus not 100% sure of your base price, but anyway, this didn't turn out too bad I don't think. Additionally, I don't know the cost or the nomenclature for the UX1 stereo which will change the price to above 15K obviously. If you got that info, that would be great. If not, you'll likely need to get a bit of factory invoice action.
I always called it a Window Sticker. Had no clue it actually had a name.
I have mine, and took some detailed pics for it for fsc66 here.. hes associated with Winvoices.com who does repro window stickers.
Contact him if you need one.
-Gonz
View attachment 112019that is one nice sticker. Everything i see on it is correct other then it is a t-top car and i didnt see that on the sticker. U even have the correct vin. Do u know if the t-top option was on the sticker? How much do u want for 1of these. Your work is amazing.
-Gonz
I already hooked him up with his contact info in post #9. They do some very good work. Mine's not concours, but pass-able.
T-top CC1 is near the bottom in the first column of options.
Of course it's the correct VIN. It's from the picture of your SPID. 🙂
Reactions: Texas82GP
I didnt think u would be able to see the vin with the pic i posted.
It's right on the very first line. And all the RPO codes that followed. Your car was a dealer order for stock also. Which kinda doesn't mean squat, because all dealers ordered their cars. But I guess it means it wasn't a fleet order. Whatever "1AY" actually means. A dealer could have special ordered it for a customer, but that would make the RPO "1AZ". I haven't seen Olds use that RPO, so I'm not sure what that's really about.
Either way, whoever had the responsibility for ordering that dealer's stock, that guy knew what he was doing loading them out like that. Most dealers cheap out on the options.
That baby is loaded. Took a long while to find it but once i did i pounced on it. Had everything i wanted. Amazing to that everything works perfectly. Hard to find that on 80s car.
hmmmmm, they didn't build a car in the 80's where everything worked perfectly....🤔
Reactions: fleming442
