Hey, those two plugs aren't interchangeable, or I should say you need to use the plug of correct 'reach'.
Right you are, my friend. The plugs I had were for the straight plug 305 heads. I thought I could just throw them on these angle plug heads without thinking that the angle would affect the reach of the plug. When I had issues firing it up, I checked the manufacturer's recommendations and these longer plugs were what was suggested.Hey, those two plugs aren't interchangeable, or I should say you need to use the plug of correct 'reach'.
Thanks for the tip, man! I'll look for one that matches my intake. I'll update when we're up and running again.For intake manifold gaskets I like to use embossed shim gaskets rather than fiber ones as they resist being sucked in better.
