That’s a idea! I’ve always been a big fan of the Buick’s with the 3800 motor. Especially the supercharged and turbo models!That engine demands a centrifugal supercharger.
I hear that, this car came with a new four core aluminum radiator and dual electric fan set up, also a 170 thermostat. It runs pretty cool. It also has oversized front coil springs and oversized sway bar. I’m thinking ill put a 4L80E in it and dump the 700R4 that’s in it now. I’m sure i’ll end up putting sub-frame connectors in it also. I don’t want to twist up the car doing the g-body shuffle.One thing to consider is that these cars weren't built with HD parts like the old muscle cars you owned back in the day.
More power means that you will need a better cooling system,stronger transmission,driveshaft and rearend,better brakes,frame & chassis bracing,then if you are driving on any twisty roads you will want better suspension pieces.
Trust me,there is no end to the list LOL
Guy
I didn’t realize the Grand Prix is a full frame car. I always though all G-body’s were sub frame cars. Learn something new every day!Sounds like you have some good parts in there already.
But you wont need subframe connectors as these are full frame cars.
Heres a link to a lengthy post on here about frame bracing ;
https://gbodyforum.com/threads/f41-and-aftermarket-bracing-diagrams-more-pics-added.8126/
If you have time you might find it an interesting read.
I've used some of the ideas in here,at one time there was a junk yard here with the older G Body's and I got some Pontiac GP braces,as well I have made some of my own.
Guy
I will always take a better handling car over comfort. I will definitely be looking to add bracing to my car when the time comes.Heres a link to a blog I made a few years ago on the mods that I've done to my Monte;
http://guysmonte.blogspot.com/2014/07/my-suspension-upgrades.html
I also put a UMI shock tower brace on a few years ago;
http://umiperformance.com/catalog/index.php?main_page=product_info&cPath=8_404&products_id=911
All the extra bracing and stiffening you can do well make for a better handling car,although it may be a bit rougher on the highway.
Always seems to be a trade off.
Guy
Yeah I thought you might and hoped you would try and talk me out of it.Well I know that I'm a bit biased,but if it were me I would stick with the Big Block,LOL
Theres lots that can be done with a 454,the 496 stroker build is one of the most popular.
I was thinking about that when I rebuilt mine,but I like to be different and went with the 4.375 inch stroker crank and made it a 513.
I also chose better handling over comfort,and it's not terrible,the wife doesnt complain when we go on trips.
Theres a set of 5 corners going up a slight hill on the way to my buddy's place that I call my "Test Corners".
I can tell you that there's no way that a stock Monte SS would ever come close to the speeds that I can reach on these corners,and I haven't pushed it to the limits...
Guy
