Been working 7 days/week for the last two months so progress has been slow, but I finally finished wiring up my intrepid fans.
They are two speed fans so I have the first speed wired up to fused relay that is triggered by a ground from a switch mounted in the dash.
The second speed serves as a safeguard in case I or someone I let drive, ever forget to turn on the fans manually or just in case the motor is running hot and needs it. It is wired up to a fused relay but it is triggered by a temp fan switch that comes on at 220 and off around 200.
I used a fuse/relay box I got at the junkyard, you can kind of see it next to the condenser on the top left. Once I finish mounting it, I can get some better pics. I made the brackets I just need some nuts and bolts.
Also finally got my plug wires I ordered, so I can get rid of that spaghetti of wires all over the place. They are 40ohms/foot, not the best but a lot better than the cheap autozone ones I have on there.
I want to route these under the headers, so they are barely visible but needs some ideas on how to do this... Just need some ideas on how exactly to route them so they dont get all burned up by the headers because it is tight.
