Tires all day long..... the frame is diamond (1 rail shifted), so the rear suspension goes like \ instead of I. I put Vista Cruiser coils in the back to keep the tire from rubbing. I think i was telling 500/600 that I may order up some coupe springs for racing to let it squat. If I'm swapping tires, what's 2 more bolts to change the rear springs? He also said his Nittos work well at 27-28psi. I started at 22, they got up to 24 with heat, and seemed to work better when I knocked them back to 20 hot. I don't know because I'm not consistent.
EDIT: coupe springs ordered..... Fusick lists the same rear spring from 61-87 for $165. G bodies are 78-87, so Moog 6319s from rockauto are on the way for $53
