So more progress. I got the fuel system in, engine and trans full of fluid, headers installed for real and the cooling system more or less installed. Then I found out the starter was failing so I swapped the one from my work van and found out the new fuel pump was a dud as was well. So I got a new starter sent to me, and am waiting on a new fuel pump. I did pop a new wheel on to have a look at it.
Still need my hubs to get made but I'm still waiting. To illustrate why I had to go with bigger wheels, here is my new front rotor on my old keystone classics.
To kill time while I waited for that I got the old front suspension out and started installing the new stuff. I decided to start installing the new brakes lines, booster and pedals, at least until the new pump shows up.
http://i50.photobucket.com/albums/f342/shadyduk1979/20160901_214149_zpspo0h0gy2.jpg
I had a heck of a time dealing with walbro so I decided that I would change to a Deutche works pump. I got the pump swapped over only to find that while I did in fact have more fuel pressure, it wasn't nearly enough. After a ton of hair pulling, buying a second fuel pressure gauge and 3 off brand filter regulators from autozone I was frustrated so, I ordered a wix filter regulator online since nobody had one locally. Get it installed and bam fuel pressure at the rail. Car fired right up.
http://vid50.photobucket.com/albums/f342/shadyduk1979/20161129_180626_zpsuztjncb3.mp4
Over the holidays work slowed a bit mostly because the bmw started smoking like crazy. I thought it was the turbo, so I rebuilt it. Then the car would overheat in 15 minutes idling in the driveway in the winter. I was at a loss why, and ended up pulling the head. Turns out it was junk. I had a spare but to get the head ready for a turbo, it needed everything replaced. So I went with bigger valves and cam than I had previously. That's running again.
So now I have been working on the camino again. I had cut my spindles and painted them before I got my brackets for the brakes. I ordered a set of the wilwood hubs. Excited that I finally had hubs I decided to install the front brakes. I got the
b body booster and master cylinder in with a automatic brake pedal and went to bolt on the brackets only to find it didn't cut nearly enough off. Also the wilwood hubs are a bit to thick to fit in the new rotors. I'll have to get the hubs machined.
http://i50.photobucket.com/albums/f342/shadyduk1979/20161009_152800_zpsjoe6n5ty.jpg
In the meantime I also realized that there was no way I could fit the truck pedal in my car, so the same caddy I got the seats out of gave up its gas pedal. Swap 2 wires, and it works.
I also got all the parts to rebuild my rear diff. I am keeping the stock 3.73 rear gears but am adding Moser axles and a eaton posi.
http://i50.photobucket.com/albums/f342/shadyduk1979/20170103_151228_zpspywy0fxe.jpg
The bmw hit me hard financially so I think progress on the car might slow a bit but I can still get the dash controls working, install the shifter, get the brake calipers brackets installed, start cleaning up the wiring on the engine etc.
More to come later!
