ok explain opening up the oil passages up top in more detail. and with what do i do this polishing?
I hope your little avatar friend doesn't show up while you are playing with rags and gas.G_Body_Enthusiast said:ok well while waiting for an answer/pics of the oil passages i cleaned the rear main cap in gas (i have no chem dip right now) and the bearing says.....STD. yay it hasn't been turned so most likely i can reuse the crank.
i'm slowly cleaning the block, wire brushing it, wiping it down with gas (trying t0o get the paint off the block) and it's looking better. i could crack loose the three plugs near the cam at the back of the block. any tips for getting them out?
