Not sure if anyone still follows this thread.. but here are a few updated photos and I still need help with clearing up a few issues!
Have you pulled the valve covers off and found the casting #'s on the heads ??
Your performance goals will depend a lot on your budget.
With the right stock Hi Po parts a big block can easily make 1 HP per Cubic inch.
Aluminum heads with the right camshaft can make more than that.My old 468 with Brodix Race Rite heads and a UDHarold custom grind solid roller made 550 HP,which works out to 1.17 HP/CI,and that was with the stock LS-6 bottom end.The beauty of aluminum heads is that they put your BB on a 80 lb diet.
If your still running the stock 7.5 rearend you should put some thought into something stronger,like a Grand National 8.5,or a Ford 9 inch.
Brakes and suspension can also use upgrading,and there are many options available.
It comes down to how much money you have to spend and what you want from your Monte.
Here is a link to bracing your chassis,lots of good info here;
https://gbodyforum.com/threads/f41-and-aftermarket-bracing-diagrams-more-pics-added.8126/
If you are looking for suspension and brake goodies Mark at SC&C is very knoweledgable,he has actually written a book on How to make your muscle car handle;
http://scandc.com/new/
Guy
Sounds like you are getting it all sorted out,one of the better purchases I have made was the Ford 9 inch.
I blew up the little 7.5 and what a mess and it took the transmission out at the same time,LOL
I wonder if you have a Mark IV 2 piece rear main seal block that someone swapped newer heads on to ??
If so that might be in your favor as the Gen 5 engine was considered a bit of an oddball and you don't really hear too much about anyone using them in a Hi Po application.
IMO,this is how Chevrolet should have made these cars in the first place,with a big engine and a stick shift !!
Guy
Well it DOES have a fuel pump boss, which cuts down the possibility of it being a MK V engine.
I agree Guy. I like the feel of the heavy engine and the torque.. but I'm having a hard time getting it running the right way. That's for sure! It'll stay a big block either way, but I don't know if this engine is going to make the cut.Sounds like you are getting it all sorted out,one of the better purchases I have made was the Ford 9 inch.
Guy
Thanks for the compliment,
I'm intrigued! What do you mean? The MK V doesn't have a spot for the factory fuel pump being mechanical... correct? I thought I saw that somewhere and couldn't find that information again. The block and oil pan themselves just look OLD.
