Need advice/info on airbag setup for el camino
ElCaminoGRAN/SPORT
325
S.carolina
Today at the junkyard i found a s10 that had a airbag setup.no tanks but all the bags were there.im not thinkin of the rear bags cause i allready got the airlift 1000 bags with new moog coils and shocks.my queston is can i use the front bags in my elco and since all there is,is the two front bags and the one line tying them together what else will i need to run the setup in the front and i noticed the bags on the s10 replaced the springs and shocks is this how it goes and what kind of feel is the ride on bags(not loookiin to be bouncin like hydros) any info is greatly appreciated if they can work wana go back and grab them for they get gone thanks......D.J.
damn, i cant ever find something like that in a yard around here... the front should be very similar if not the same as your el co... how much did they want for the front susp. also, are the cups in the s10 front bolted in or welded in? what is the condition of the bags?
Around here at these pic and pulls you actually find good stuff just got get there when they first get pulled out or they get gone quick.They dont want but $20 a bag but im sure i can talk them down to $15 the bags look good and luckly are bolted down im just wondering how big a tank and compressor i need to lift them or can they be done like regular air shocks and just fill and forget,to me there cheaper then me ordering springs i need and i wouldnt mind the custom touch.Also found a rear sway bar off a cutlass for $20 i made sure i grabbed that even though i allready got one...
