need advice on new fuel pump
So I have just one more question. Do I need to plumb in a return line? I've talked to many people that said they don't run a return line. Does that hurt the pump?
Yes and no. A return line helps keep the fuel cooler, not so much the pump. That prevents vapor locking. But, most do not run a return line. With fuel injection and higher hp, like 500-600hp and above, you should run it. Carburator 500hp and below, not needed but always nice to have. My fuel pump has a return line from the pump, back to the tank. If I go with the FAST EZ EFI 2.0, I will certainly need a return line from the regulator or the sender device back to the tank.
Sent from my iPad using Tapatalk
Thanks for your replies. I'm gonna keep my plumbing the way it is and wire me in a relay to be safe. Would it be beneficial to run my ground off the pump to the negative battery cable since my battery is located in my trunk?
Not really. A good ground to the frame is more than enough, but if your frame has rot or a poor conductor, go direct or another, better location.
