need answer fast please
mysons80elcamino
Mar 27, 2012
84
just jacked up the camino and put on new wheels. after they are mounted there is only about a 1/4 inch from tire to frame in the rear is this enough. if not how much should I have its an occasional driver.
all stock
air shocks
tire size is 255-60-15
mysons80elcamino
Mar 27, 2012
84
so the back are ok now, but the front are rubbing on the tie rod, not the wheel but the wheel balancing weight.. I think im just going to get a stick on weight for inside the wheel
ALSO HOW MUCH LUG BOLT SHOULD I HAVE OUT PAST THE LUG NUT, RIGHT NOW IT IS EVEN, TOP OF LUG BOLT IS SMOOTH WITH TOP OF LUG NUT.. IS THIS OK OR SHOULD I HAVE MORE....
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,179
9,802
Gainesville, Fl
Some thin spacers should rectify that. That's what I ended up doing with mine...or like you said, stick on weights on the inside of the rims.
mysons80elcamino
Mar 27, 2012
84
So how does this look, im not to fond of the iroc's but my kid likes them
the tires still need shined up but do these wheels look ok to everyone.
Josh Hanna
130
Coral Spings FL
i have the same wheels on my el camino, you have to run the rears on the front and the front on the rear. the back spacing is backwards..
Longroof79
Oct 14, 2008
12,179
9,802
Gainesville, Fl
Josh,
Your wheels are the actual 16" IROCS, those are Camaro RS or Z28 wheels. I have the same 15" Camaro wheels on my wagon currently. They aren't front and rear specific like the 16" wheels.
