jpoole said:tobyp said:it clicks because your cables are broke and the gear from the motor is "skipping"....after awhile the moon roof will not close all the way when the gear or the worm on the cable wears out. I just replaced both my cables for the same issue.
Hi tobyp, where did you get the cables?
thanks, Jeff
I had to find another assembly that luckily had a good pair. I have one decent cable for the drivers side. You need to take the motor off to see which cable is broke
