You can thank Audi for shift interlocks
For those old enough, remember the Audi 5000 debacle?
my 94 caprice had this feature. but no g-body has this feature unless someone went out of their to retro-fit it.
if you were in a ford pinto with an audi 5000 behind you, you would think differently.I wouldn't call it a feature
Then, a square body pulls out in front of you= Pinto vaporized.if you were in a ford pinto with an audi 5000 behind you, you would think differently.![]()
Wheel chocks are important too... assuming there's enough to hold the tire and you don't just drive over the thingThen, a square body pulls out in front of you= Pinto vaporized.
Yes, it was the 90s. Thanks for the correction. The main point was, there were no brake-related transmission requirements from the factory on the G-bodies. So be careful jacking around with the shifter in there.My '99 GMT400/OBS series truck requires depressing the brake pedal before it will shift out of Park/into gear so earlier than the mid-2000's.
