Need help. I don't know jack!
fatload2
39
Whorelando FL
My car was stolen last week and when I got it back it was missing the hood and Weber carb off the 305. I found an 87 Iroc Z 350 with everything but the TPI for $250. I also found a Demon 850 and a Holley Strip Dominator manifold for like $350. Are they compatible and could I drop this in and go or should I just get another carb for my 305? I have no clue if I can change from TPI to that carb setup so easy, it just doesn't sound right to me (that and nothing is ever that easy for me)
86Cutlass383SR
720
6
Sesser, IL
Are you wanting to put the Demon and strip dominator on the 350 and drop both into your car? Yeah, it'll work but that big 850 and intake would be way too much for a stock 350 engine. You'd have to lean the carb back alot!
The 350 would be a direct swap for the 305.
Since, as you stated yourself, ... "I don't know jack", I'm wondering if you had a Weber carb or the stock carb for a 305?
The stock 305 carb was a Rochester. Did it look like this?
http://www.summitracing.com/parts/HLY-6 ... /?rtype=10
fatload2
39
Whorelando FL
Everybody looks at me funny when I say it was a Weber but yeah it was...or at least that's what it said on it. I figured that carb would be a lot on the 350. It's an L98 350 with roller rockers and a cam from what the seller says. The other seller said he would separate the strip dominator and the demon and my buddy has a Holley but not sure of the model that I could toss on there. Oh and do you think I'll have clearance issues with the Dominator? I can't really afford all of this then another cowl hood so I'd have to go stock and there's a guy selling 2 for $50 each
fatload2
39
Whorelando FL
Oh yeah and I also am looking at a 472 and was wondering if my 350 trans would hook up to it or if I would HAVE to get a 400. It's really only driven about 150 miles per month and not hard. I'd like to run it maybe once every couple of months down the strip just for fun tho
jatguit
114
4
I believe the Edelbrock carbs have Weber on their castings.
So it is probably an Edlebrock 600 or 650 guessing, for the 305 as anything bigger is pointless.
I've got a 650 AVS on my Mopar.
JBreu
2,167
20
38
Livonia, New York
X2-My eddy also had weber on it as well.....A th 350 would work with that big block....
neverendingmonte
Vancouver B.C.
I could be wrong on this but doesn't the tpi setup have a slightly different manifold bolt pattern? If this is the case that dominator manifold probably won't work, and I would be inclined to say that it isn't the right manifold for a stock tpi motor. anyone know?
Hemihauler
26
I would go and try to find a complete 350. Truck motors seem to be easier to find in the scrap yards nowadays, or find an older truck thats rotting that someones selling cheap. Similar situation happened to a friend-intake manifold up was stolen, didnot have motor checked when he put the new parts on-needless to say sh*t in motor-blew up a coupe days later. Anyways Goodluck.
86Cutlass383SR
720
6
Sesser, IL
TPI had 2 slightly differant intake patterns. 1 was the same as the older iron heads and then the other has the 2 center bolts on each side at a differant angle. The holes on each can be elongated if needed as the aftermarket TPI intakes do.
If I recall correctly, the factory alum head engines retain the same angle as the older heads. The iron heads (from about 87 up 305's I think) use the revised intake bolt angles.
clean8485
2,865
2,170
Ontario, Canada
When you say that you're "looking at a 472", are you talking about a 472 cu in Cadillac engine? If you are, and my memory serves me correctly, then your Chev turbo 350 transmission won't bolt up to it. You'll need a transmission with the BOP (Buick, Olds, Pontiac) bellhousing bolt pattern to fit it.
