I recently bought a 85 cutlass g body and bought some 24" rims to put on. Wanted to know will I need control arms with the lift kit? I have 5" cups and springs being installed on it. Let me know what you think!! Thanks.
YoungGuy said:Yes you will need extended control arms to keep your front tires square on the ground. If you don't after a while or even immediately your camber angle will be off and your wheels will look like there leaning back into the wheel well. Type in "bad camber" on google and look through images. It wont be as dramatic as the tuner/import cars but thats what it will look like. Plus if you get new control arms you wont have to worry about the stock stuff being worn out. While your at it you might want to do shocks if you haven't already. I like that cutlass to. Good luck
