Did you not set the timing with a timing light? If you don't have the timing set properly you'll be chasing problems that are a byproduct of incorrect timing all day.
Timing has been set with the advance line disconnected (and plugged) with a timing light, IIRC it's advanced by about 8 degrees.Did you not set the timing with a timing light? If you don't have the timing set properly you'll be chasing problems that are a byproduct of incorrect timing all day.
Of course it did. You have an incorrectly adjusted vacuum pull-off causing the rich condition. The vacuum leak added air which masked the condition. Remove the leak and you are back to a rich condition. When the choke opens fully the condition disappears. You need to adjust the vacuum pull-off and verify it opens as soon as the engine starts. Fully open it should be between 1/8 and 1/4" open at the butterfly. Check an older Motor manual or Chilton's for the opening on an old engine similar to yours. Later models used an angle gauge which no one has so go by the old specs. Measure yours and open it by adjusting the spring loaded screw on the linkage.despite the leak it started easily cold and ran fine,
