need info
scotfost
n00b
Apr 1, 2010
im redoing an 83 malibu wagon and would like to find out what all doors can be used to replace the ones on it or is there somewhere i can get new ones
For fronts you can use any Chevy Malibu('78-'83) or Pontiac Lemans('78-'81)/Bonneville('82-'85?) 4-dr or wagon.
The rear doors are wagon only, and are different than a regular 4-dr.
'78-'83 Malibu and LeMans/Bonneville wagons are your matches.
The difference in the rear doors is the frame around the window. The lower shell is the same.
If you're brave, you could cut the wagon window frame off and weld it onto a clean 4-dr shell.
