Need Some Advice About a Water Leak
Not sure if your car has a/c but look at the picture below, the fan is circled in black. There are a few screw holding it on. When you remove it look down inside and remove anything thats down there pine needles, mouse nest and other junk. The drain hole is at the bottom hard to see. Run some water on the windshield and you will see water running inside that opening and should be draining under the car.
That makes sense. Thank you.
I am confused by your post. Is water leaking onto your seats or the floor?
Both sides .....???
maybe upper door frame seals or the windshield cowl?
Yeah a new windshield cowl weatherstrip is cheap ($16 ish). I will be ordering that today probably from rockauto. What do you mean by upper door frame seals? Sorry, but this body and weatherstrip/seals/etc stuff is all foreign to me.
Reactions: 85montess
If it was the door seals, would the pillars or anything else be wet? The water would have to run down some how to the floor, no?
Just a guess
I have seen the floors wet from the seal before without any other evidence
I would check the car with a hose before I do anything.
Reactions: dr78442
For sure. At this point I am open to all suggestions and help.
