Ok so today I was stopped at a red light and thought I smelled something burning. I got the car home and there was smoke coming from the driver's side of my motor. I got under the car, and took a closer look. I cleaned up the underside of the motor with degreaser, brake cleaner, and paper towels. I started up the car and let it run. I would give it a little gas now and then trying to make it leak. Eventually I see oil running out of the top of the dipstick tube and down on to the block/exhaust, and burning off. So I'm sitting there watching oil run out of my motor going
First thought was that maybe I had a clogged pcv valve. I took the pcv valve out completely, and cleaned up the motor again. I drove the car about a mile down the road to autozone, and pop the hood. There is no oil on the outside of the dipstick tube. So I was thinking I had the problem solved. I go in the store and buy a new pcv valve. I put the new one in, and drive around town to see if things were fixed. After a like ten minutes of driving, I am smelling burning oil again. I get the car to my house, and it is still leaking out of the top of the dipstick tube.
What could be my problem? The car is a '84 Cutlass with a '69 Oldsmobile 350. The driver side valve cover has a breather filter with a hose that runs to the air cleaner. The passenger valve cover has a pcv valve with a hose that runs to the front of the quadrajet. I had been noticing a little oil around the bottom of my oil cap for a few weeks, but nothing ever this serious. My next thought was maybe that breather filter was clogged up.
What do you think it could be? I need to get my car back up and going. :|
