Need to ask convertible owners some questions
Bonnewagon
9,830
12,628
Queens, NY
Too bad, there are no convertible G-bodies. But I have a 1968 Firebird convertible. I replaced the O-rings in each hydraulic top cylinder and they are working great. Maybe too great, because on one side the hose fitting blew out from the cylinder. The threads are just stripped right out. I need some new cylinders. I see imported junk on Fleabay and I may grab a cheap set just to use while working out the bugs in the top mechanism. But later I will need a good set and I want USA made, which is not hard to find. My questions are: Why are some cylinders one piece bottoms like the originals, and why are some capped on the end? I think 'swagged' is the term. Is either kind better? Many companies sell 'USA made' but I only see a couple of actual manufacturers. Convertible Service, Hydro-E-Lectric, Auto-Pro, and the one that caught my eye, Convertible Cylinders Direct. https://www.convertiblecylindersdirect.com/Convertible_Top_Cylinders.html These guys are a family run business in New Hampshire. They offer a 7 year warranty which is better than anyone else. They sell from their own site and on Fleabay where they have a 100% rating. Anyone use them or know about them? If you have used any of the others, what is your opinion? I'll have more questions later but for now I need to know about these cylinders so I can decide what to do. .
ck80
Moderator
Moderator
5,500
8,513
Unfortunately the only gbody convertibles I see regularly were conversions done on some early style regals, usually around 1982 and 1983.
I've got a slk320 power hardtop. It had one cylinder go bad so we replaced all of them from the OEM supplier. That probably wouldn't help you.
As far as the swaging, not sure if this will help you or not, just from an educational standpoint: https://www.qform3d.com/processes/rotary_swaging
Bonnewagon
9,830
12,628
Queens, NY
Yes, that helped a LOT. The video really showed the process and I get it now. Swagging the ends probably makes the tubes stronger than they would be just cast as is. I'm guessing the OEM closed end tubes were just less expensive to make that way. I did order some cheap cylinders just to use for now. If i ruin them then I'm not out much. I still have a lot to do with the top mechanisms before I can even think about replacing the fabric.
