Hey guys I recently dropped the THM200 transmission out of my 1985 Regal Limited and am looking into replacements. I couldn't find a similar thread so I'm hoping this will help others as well. I have a lot of questions and options so bear with me. I'm having trouble deciding between replacing it with a 200r4, 700r4, turbo 350, or having my current one rebuilt. I'm wanting better performance and if I can get better MPG that'd be great too. What are some of the pros and cons of each?
Here are a few of my problems:
I've heard the THM200 is garbage and not fuel efficient, therefore not worth replacing?
Would the 200r4 be a direct replacement with same cross member and linkage?
I've been told the 700r4 is my best option, but it's a lot more expensive and might require additional modifications to work (bell housing, drive shaft, etc.)
Shops have said there is a lot more work installing a turbo 350 such as custom mounting brackets
Can I keep my stock column shift with any of these without difficult modifications?
Is it difficult to install an over drive trans on a car not equipped for it?
Any input would be appreciated and thanks in advance.
