I am having some performance problems from my new 350 just dropped into my 80 Bu.
1976 block and heads. bored 30 over.
Professional Products highrise intake.
Professional Products Dist.
Quick Fuel Technology Slayer 600cfm Carb
AC Delco plugs
Taylor 8mm wires
290/500 cam
stock exhaust manifolds
2.5 piping into Thrush welded muffs
the engine starts perfect and idles well. in gear idle is kind of low, but doesn't die and stop lights.
problem is, it is not anywhere as snappy as it should be. it will NOT even turn the tires over from a dead stop, in low gear, and on wet pavement.
it will NOT even power brake.
it is timed at 10 BTDC. and I didn't set the carb. although I am sure that it is running rich. I have yet to research on how to adjust the air/fuel in a QFT carb.
any and all help you can give will be greatly appreciated. I am open to all suggestions. thank you in advance.
AC Delco plugs
Taylor 8mm wires
290/500 cam
