Newly rebuilt from a local shop 700R4 - Specs from the shop: W/ TCI CONTINUOUS PRESSURE VALVE BODY,TCI SHIFT KIT, THE BEAST HD SUNSHELL, CORVETTE SUPER SERVOS, RED ALTOS CLUTCHES, HEAVY DUTY SPRAG ASSEMBLY, WIDE RACE BAND, also has a 2500 rpm lock up converter. This trans is behind my 1980 Malibu with a 400 small block with approx 425-450hp and 3:73 posi rear end. Carb is edelbrock 800cfm Carter style and I have the Edelbrock corrector bracket on the throttle lever. I measured the distance from the centerline of the throttle shaft to the TV connection point at 1 1/8" and I have 1 1/4" travel of the cable from idle to WOT.
The issue I'm having is that it will not shift into 3rd gear at WOT with the TV cable adjusted correctly to be fully pulled out at WOT. 1-2 shift is fine but no 2-3 shift. If I let off or go 85-90% throttle it will shift into 3rd. If I back the TV cable off a 1/8-1/4" it will shift into third at WOT, but the shift is soft. Also, when adjusted like that the part throttle shifts come way quicker than I'd like. If adjusted for full pull at WOT the part throttle shifts are spaced out better.
My trans guys is stumped and I'm starting to think I went to the wrong shop.
I'm starting to wish I went 4L80E, but I already spent the money on this 700R4. Any ideas?
