Well I just am getting a 1979 Olds 88 with a 403 in it with 52,000 original miles from my girlfriends parents I am pulling out the 403 and what I think is a 350 trans, i will no more once i get it home, and I am going to scrap the rest for extra money for the build, and plus it is a pile of crap other than the motor. Here is the thing this is going to be a fun low budget motor build untill i can save up for the big block build and the beauty is it will drop right in place of my 307 because good ole small block olds use and same motor mounts and i can use the acessories from the 307 😀 . So here is where i need help i know that these motors make about 185 hp and about 300 lbft of tourqe, thats all fine and dandy but i am wondering some easy things to make some more power I was told that if you put a good cam and a set of olds 350 heads it will boost the power i also plan on gettin a set of dynomax headers for this application as well. Any suggestions on heads, cam durration, or any other port and pollish work or any other things is welcome.... once again this is a temporary budget build to satisfy me until the big block comes so this thing does not need to be a monster that will come later. Also any ideas about a rearend fix for now can i make my 7.5 strong enough or should i bite the bullet and by a 8.5 now.....
