my 83 cutlass went 13.30s at 107mph with this combo...
Stock bottom end.. STOCK no mods.. dont worry about the mains.. as long as your not running NOS, 12.0 compression and spinning it beyond 5500 for long periods of time...
Stock bottom end... and i mean stock.. just re-ringed.. even down to a stock SAgear timing chaing and Melling M22 oil pump and pickup
1972 350 heads, stock valves.. Egr bumps ground down...
Comp Xe262 cam .475 .480 lift 218-224 dur. @ .050
Edelbrock Performer Intake.. (i tried the RPM it made a noticeable difference in top end power.. but never ran it at the track) the rpm will also NOT clear a stock hood..
Home rebuilt 750 Q-jet
Stock manifolds and true duals no cats...
3.73 rear gears, with a Tci streetfighter Th350.. this is a 12 second combo if you run headers and sticky tires, but if you have the stock 7.5 rear sticky tires arent a good idea...
with the 350 heads and a fel-pro gasket your compression will be somewhere around 9-9.5-1 if the heads are milled.. but if you have some extra coin to play with, a set of flattop pistons and ANY big block olds head would probably be a good choice too..
