I used a thicker head gasket to pull it down a bit , and just don't go crazy on timing. All good .Nice! 11:1 on pump gas?? I've been curious what you can run for compression on 91 pump gas?
Iron heads vs aluminum? I believe you can run more with aluminum?
Pistons and deck clearance weigh in on compression totals of course. The Pistons were 11:1 , went with I believe a .045 gasket. But to be honest 11:1 is not to far out of the scope for 93 octane. I believe GM used a .020 thicknessCool! Should be a lot of fun!!
There are some really good reads on the issue actually. I'm sure there's plenty right here on the forum .Pistons and deck clearance weigh in on compression totals of course. The Pistons were 11:1 , went with I believe a .045 gasket. But to be honest 11:1 is not to far out of the scope for 93 octane. I believe GM used a .020 thickness
There's just alot of factors IMHO when calculating compression ratios. Heads 64 cc or 70cc , cam etc.There are some really good reads on the issue actually. I'm sure there's plenty right here on the forum .
