If you don't mind I have 2 more questions.monte SS, GN, 442 all share the same exact steering box, right down to the part number.
Most mass rebuild places like auto parts stores rebuild whatever box they get. Vice versa, if you have a "slow ratio" box and get a quick ratio from say, Advance Auto, you can plop your old one in the return box and trade it in as a core. Which means someone looking for that GN box that's quick ratio may be in for a surprise when they go to Advance and buy a steering box for a GN.
The best way to ensure you get a quick ratio is rebuild it yourself, or farm out the job to a place that will return YOUR box. Or do like 565bbchevy suggested and buy one from a reputable vendor so you know what your getting.
If you can't find one of the above boxes, internal stops need changing in an F41 Camaro/Firebird stops, otherwise they're good choices. Only negative thing about them on a G-body is as-is, your turning radius is reduced.
What is the part number you mention above?
Is it plug and play, or do I need to adjust or change something with the shaft? I'm a big fan of easy and plug and play.
Updates - I did some additional research and the local Auto Zone has Reman Cardone steering boxes for the Monte SS. I can pick it up so no shipping and I can return the core. The case is 170.00 for the one supporting the Monte with Sport Package [Z65] and the other is does not support the sport package for 150.00. Are they both close ratio? I'm guessing the former is.
