Nice to see you saving another Buick. That car needs alot of love. In my opinion, your best bet is to find a non-running/wrecked/parting 86-87 T Type, and buy the whole car.
My 87 GN had a strange water leak on the left side that I was having a horrible time finding. I found some rust pin holes in the drain area below the wiper motor when I stripped the car down and media blasted it. Mine was small enough that once it was blasted I treated the metal and covered it with some seam sealer. Unfortunately you will have to remove the dash and everything in that area to replace that piece. There is some sound deadening in there that will catch fire when you weld so you will need to get all of that out of there first. If it was me, that would be the first area I would repair as that is most likely why the floor pans rusted away.The cowl and the front of the roof where the tops sit is what worries me. I think once I get the parts car here I will remove the front clip and start examining on how to go about patching it in. I think most people are comfortable doing basic floor pan patches. I’ve never done it but am going to try it in small sections. If it doesn’t work out I’ll get a body guy to do it.
I planned on removing the dash anyway just to clean everything and put new insulation/sound deadener on the firewall was going to repair it then. The front of the t top bar also contributed to it I thinkMy 87 GN had a strange water leak on the left side that I was having a horrible time finding. I found some rust pin holes in the drain area below the wiper motor when I stripped the car down and media blasted it. Mine was small enough that once it was blasted I treated the metal and covered it with some seam sealer. Unfortunately you will have to remove the dash and everything in that area to replace that piece. There is some sound deadening in there that will catch fire when you weld so you will need to get all of that out of there first. If it was me, that would be the first area I would repair as that is most likely why the floor pans rusted away.
Very cool score. Would this car have had the 4.1 V6 originally? Liking the Lear seats too. I hope you can find the correct seat covers for them. Will be looking forward to the updates.
