Are you on Turbobuick.com? There are many posts on starting a long sitting TB. There are also recommendations for TB specific shops in that area for items that you don't want to tackle. If you happen to get it running I would not run those chips. I would pull the chip you have and see what it is. The kb chips have way too much timing for a today's fuel. You need to first get the systems checks out, either by you or by an expert. The oil pressure you have is fairly typical of a TB. Astro roofs are better than t tops for strength so you are ahead of the game there. Chances are there are many old school mods done it. I would definately replace the fuel pump with a Racetronix hotwire harness and pump. Next you need a scanmaster if you don't have one. Then a Turbo Tweak chip. This is after you know what you got for parts and what shape the engine is in. Don't get ahead of yourself until you know the health of the engine and transmission. It sat for a reason! You need to find out why...
I'm assuming it already has a hotwire kit for the fuel pump but I have not checked yet, it does have an accufab adjustable fuel pressure regulator on the fuel rail, which I would assume would serve no purpose without a hot wire at the very least, and I suspect something like a walbro 255 or something similar in the tank, but like I said I haven't checked yet, it's been cold and windy, or rainy at lot, don't feel like doing work in weather like that.
It does have a turbo tweak chip in it right now, but I don't know what kind of tune it has, pump gas, race gas, meth injection, etc. I am going to get a scanmaster, I'm actually surprised it doesn't have one already. Tempted to get a MS3 plug and play standalone so I can tune it myself and have multiple tunes that can be switched remotely without having to physically change parts, like a chip.
Is the gauge style scanmaster the same as the boxy one? I like the idea of being able to stick it in a gauge pod rather than Velcro to the dash the way a lot of them look.
The car does run... I'm just afraid to drive it because I'm afraid of doing damage to it, if it already hasn't been done. It has an adjustable waste gate, and some kind of manual boost controller, neither of which I know how to adjust. The boost controller just has a dial with a +/- sign on it. The turbine housing says Precision on it, so it's not stock, but I don't know what model turbo it is. It's also got a big aluminum griffin radiator with electric fans, external oil cooler and trans cooler plumbed with AN fittings. Front mount intercooler, again, obviously not stock. And considering the 28x10.5 slicks on the back, I imagine it's got more modifications that I haven't spotted yet.
