You could even make it a blow thru setup....View attachment 176015
LALALALALALALALALALA. I’m not listening!!!!
(Even tho I already have Vortec heads on a certain car…)
People have gotten wise to that as well..The 6.0 thing is the same around here- they go for stupid money for Gen 3's and Gen 4's are generally going to be had buying a complete vehicle or $2k +
Leakdown usually is bad on an LS due to valve seal. If it's rings, then it will need an overbore. At the moment, the point I'm at in my life is that I don't intend to go though the bottom end of a stock LS ever, hence my comment that the next one is less than $500 and 10 minutes away. A quality valve job and good set of springs are not a waste of money AT ALL. If you want to spend money SBE LS's, then new oil pump, lifters and lifter trays.People have gotten wise to that as well..
I had to drive 2 hours and drop $1200 on a 230k mile 6.0... and it needs gone through because once I got it home and did a leakdown test... It's not great. It ran and drove but that doesn't always mean it will last a while.... So to save myself from pulling it again later.. I'll go through it now.
Hopefully next weekend I'll have some reasonable results of a completely stock bottom end
Complete, turnkey 6.0s start at $800-1000 around me.....200k+ miles of course. Running/Driving donors can be had reasonably....you just need to know where to look.Where I live the junkyard 6.0’s go for a premium, a cored short block averages $1200. The iron block 5.3 can always be bored 30 over down the road. If I’m buying a used motor I’m still doing a partial tear down with heads removed for cleaning and inspection, I’m not going to take any chances especially on a higher mileage engine. So again, it’s better for me to just start with new stuff and make it the way I want it.
Did I mention your eligibility for the buddy discount?
This is how it starts.I decided to pop the oil pan and inspect my rod bearings, if the rod bearings are good typically the main bearings are fine.
Everything looked fine, I was ecstatic. Pulled the heads to replace the HGs with MLS jonnies. Decided to put new lifters and trays in it, since it was apart.
Disaster.
Ended up having to hammer the lifters out through the bottom. Fun times.
Since I was already that deep into it I decided to put new rod bearings in it. Pulled the pistons out. 3 of them had broken rings. WTF.
That's when I decided fck it and just ordered new pistons and rings.
Honed that biddy out with a 3 stone and slammed it back together.
At the end of it all I was actually happy all that dumb sh*t happened, otherwise I never would have found the broken piston rings. That wouldn't have been fun.
I absolutely enjoy the whole don't look at anything and slap it together method, but sometimes it does pay off to spend a little time investigating the situation.
LS = 'no love'
Throw that beech in the trash pile and grab another. If the cam bearings aren't spun then send it!!!! Falling in love with an LS is like watching a virgin at the wh*re house.
Lifter trays from BTR - less than $40, budget lifter $8/per, BTR head gaskets -$40; stock, reused head bolts - free. 20 psi and send it!!
