So due to situations I don’t have the time or money to properly fight this issue I’ve been having with vapor lock and fuel boiling hot starts and operating temp of about 220
That said I live in Florida land of hot and rain unfortunately I’m thinking based on browsing google if I were to wd40 or Vaseline my important electrical connections, as long as the carb doesn’t fill with water in between drives and I make sure the local crackheads don’t try and steal my parts I could theoretically run no hood until I figure out a different solution which will lower my temps and give me the clearance to install a carb spacer I already have and hopefully resolve all of those issues in one go.
The other thought is spacing the hood off the hood hinges in the rear and removing the rear weather seal on the cowl giving me more room for heat transfer and possibly enough room for my spacer.
I already have a drop base air cleaner from summit and I believe a 3 inch filter element I’m not sure I’d want to go with a smaller filter for clearance purposes and I’ll likely go shaker or cowl induction at some point. Plus I may need a mullet to think so but for some reason I think a goody with a carb v8 looks awesome without a hood.
This is my set up under the hood with no spacer under the carb.
