I didn't see an answer as to whether or not this is a factory setup. Is this a recent failure? Did it never work before? New problem? My Cutlass has a bad TCC solenoid and I've been driving it for months with no ill effects.
as far as having a od trans from factory yes, motor was only swapped in not trans , was working fine till the other day now it WILL NOT ENGAGE LOCK UP i checked the brake switch seems good also has power to a green wire on the plug on side of trans thanks for your time cheers
