khan0165 said:while we're on the discussion, I went out and took some pictures for you guys tonight. These are BFG G-Force Drag Radials, 275/60R15s mounted on 15x8 Corvette Rally wheels, with 4inch backspacing. The rear frame rails on this GP have been replaced, and so could account for the tighter fit.
passenger side, inside view, NO spacer
drivers side, inside view, NO spacer
passenger side, inside view, with 3/8" spacer
drivers side, inside view, with 3/8" spacer
and here's how close they are to the fender lip, using a 3/8" spacer.
it's tight in there...
the 60's fit with no problems put the 50's on there and you will have problemsStg1Regal said:I have a 82 Regal with GN 15x7 rims with 275/60/15 mounted on them.... ran that setup on both my 82 Regal and my 86 GN, no clearance issues..
heres a couple of pics of the Regal with the GN rims and those 275/60/15's mounted on them.
hope this helps
efigp83 said:the 60's fit with no problems put the 50's on there and you will have problemsStg1Regal said:I have a 82 Regal with GN 15x7 rims with 275/60/15 mounted on them.... ran that setup on both my 82 Regal and my 86 GN, no clearance issues..
hope this helps
1983regal said:...the only difference between a 60 and a 50 series is that the 50 is a shorter tire why would they not fit?
