dan2286 said:That sucks. Just to make sure pull off a valve cover so you can verify the chain is broke.
Just to let you know, I had to re set the valve timing on mine on a gravel driveway and it wasnt that bad. Actually, all work I do on the car is on a gravel driveway since I cant move it because of no front suspension. I somehow managed to get my drivers side header in when it was 30 degrees outside 8).
well I figure if it was a cam gear I'd be able to turn the dist shaft right? besides there is no noise ... hard enough for me to imagine it's the timing set but if the dist or cam lost teeth would there not be ALOT of metal on metal ... that said I do need to do valve cover gaskets anyways .... I already bought those and have been waiting on my not to be lazy. A big part of me just wishes I knew of a running Olds 350 laying around.
