Yeah, I defiantly recommend an aftermarket timing set, originals suck and will leave you broken again way before it's due.
midwestls said:I usually throw (sacrifice) a ratchet or extension through one of the holes on the flex plate and turn it to where it wedges up against the block itself, then as Blake said use some kinda bar/pipe over your breaker bar. Usually works pretty good.
85 Cutlass Brougham said:It's pretty much standard practice. I have done it many times with no real issues.
