Hello and hows it going? So I am putting a 454 in a 84 monte, I was working on getting my headers in place last night and I noticed the that the oil pan is ever so slightly touching the cross member at each corner of the pan. In my mind it doesn't seem like it would take long to rub a hole through the pan if I leave it as is. I am just trying to figure out what my best course of action is...should I dimple the pan with a hammer, do some grinding of the cross member, or a combination of both? On a less serious note, the brake line that traverses the cross member is also contacting the oil pan in the same general area. I was thinking maybe I could put a rubber sleeve over it to protect it from rubbing through...I would appreciate some thoughts on that issue too. Here are a few images, hopefully they are clear enough to see where my problems lay.
