whats an easy way to change my oil pan gasket in my 83 montecarlo with a 305 without pulling the motor?
yeah i figured that its the last thing i need to do to the motor to get it up and running again thanks yallI don't believe there's enough room to do that. The oil pan won't clear the pick up tube. You'll likely at least have to remove the engine mount bolts and lift it another couple inches.
I tried to do this on my 455 in the car to check the rod and main bearings, and it didn't work out so well. That's how I know... Lol
