If the rings are done, then that means that the piston chambers probably have a ridge that needs to get bored out. Which then means new pistons. The subtle knock, you couldn't hear it unless you were really, and I mean really, listening for it. The only reason I noticed it is cause I built the car and can tell when the slightest change occurs, which I'm sure most of us can do anyway with our cars.
On top of any engine expenses, I still have to get the 700r4 rebuilt to hold 400hp/450lb. Then tear out my carpet because I have 3 massive holes in my floors from an exploded driveshaft.
The reason I'm leaning towards the roadrunner is because I'm kinda fed up with the malibu right now. It never started having problems until I had to drive it for 3 hours on back road highways to get to college. Even then, after swapping to highway gears and babying it, I had to fix something every weekend when all the stupid parts were new. I'm sure you guys have had the same feeling at some point with one of your projects.
Yes I do all my own bodywork, paint, engine builds, etc. Only thing I can't do is any machining. The point to roadrunner is to gather up parts now so that when we do start, everything is there.
What will be the deciding factor is if I pop that oil pan and the crank is ok and the piston chambers and rings look good. If they don't, and I have to do a full rebuild on this engine, then it is going to sit. It really sucks to put over 5 years of effort into building a car and having the ONE AND ONLY stock piece of the drivetrain, the driveshaft, to give out when it never showed any issues. I had sandblasted that thing down the weekend before and it was solid as could be, didn't think I had to magnaflux the damn thing. Frustration is the evil red eyed monster that will kill us all.
