Ive been using Chevron Delo 10w-30 in my 1994 Lesabre since I bought it at 60,000 miles. Now at 130,000, The intake valves couldn't be cleaner as per my borescope. My Chevy K1500 has had Rotella 15w-40 in it for some time. Diesel oil is more robust than gasoline oils, and it also has stronger adhesive and cohesive properties than gasoline oils, which makes up for the lack of startup flow.
Diesel oil isn't stronger or better. It just is formulated differently since diesel engines have different contamination buildup issues than gasoline engines. The stronger adhesive and cohesive properties is simply greater viscosity, which doesn't offset the poorer startup flow. Plus thicker oil has greater fluid friction which increases heat and reduces oil life and performance.
Diesel motor oil has greater additives per volume because diesels burn dirtier and deal with more soot and blow by contamination than gas engines. The extra detergents in diesel oil will reduce ring sealing in a gas engine and cause compression loss. In some cases, diesel oil detergent can cause faster cylinder wall and ring wear in a gas engine, depends on engine design.
Now some commercial diesel oils are dual rated and can be also be safely used in gas engines. However a non dual rated diesel oil should never be used in a gas engine, these are the oils that will cause faster cylinder wear. In other words, diesel oil commonly has higher TBN, because diesel engines have more blow by and require it. However, such high TBN isn't good for gas engines with lower amounts of blow by to deal with, and the excess TBN can lead to adverse reactions. A dual rated oil has TBN between diesel and gas specifications. But you still need the proper viscosity.
As I said before, thicker than specified oil in a engine causes extra wear, not reduction, between poorer cold flow and poorer splashing, plus greater friction. Too many G body owners believe in old wives tales.
