I don't usually mention suppliers/manufacturers names but in this case I'm not trying to discredit anyone.
We use Brad Penn in all our race cars and street cars (older cars, no emission cats) My friend put Brad Penn in his 2003 F-150 and it ruined the Cats. When we suspected the oil was the issue, I call Brad Penn and they said, it could have been the oils additives that cause the cat failure.
It's cheaper to call the manufacturers and ask then to repair later.
As an automotive Tech for 27 years, I'm all for synthetics...No cons there for me. There are way too many myths about oils and synthetic oils out there, and I'm not going to get into a huge debate about it. Use them if you would like... they are better. I wouldn't stray too far from the viscosity that the manufacture "designed and machined" the engine to operate with. Some newer cars have variable rate oiling systems, changing the oils viscosity will starve the motor for oil. I'm not saying this will happen to yours but fact is they designed these engines this way. They designed yours a certain way too.
Use good oil (Valvoline, Max life, high mileage, full synthetic) and don't forget a good filter (Napa gold), change your oil often and you will never have any issues.
