NGK TR5, TR6, BR6EF or BR7EF depending on if the engine is stock, high performance NA, on a little nitrous, or heavily boosted.
The BR-series are non-projected tip. The TR5s are stock heat range and the 7s are two steps colder.
Also these are all copper plugs and work great - because they are copper it forces you to change them about once a year and therefore forces you to keep closer tabs on how your engine is running.
Cooper plugs are the best to use, they give the best performance cause they are the most conductive plug. The platinum and iridium plugs are not as conductive, they heat up more than the copper plugs with their high resistance but those materials last longer than copper.
