Hey all, I have a 307 Oldsmobile engine in my '86 Cutlass Supreme. Today I went and started it up and it ran fine up until I put gas in it. It started to run sluggish about 1 or 2 miles away from the gas station. It sounded different too. I stopped at my buddy's house and let it cool down so I could put oil in it (thinking it may be low on oil). I put a quart in and drove maybe 3 or 4 blocks away to the next gas station and put 2 more quarts in. I drove it home very careful thinking it may break down and leave me without a vehicle. When I got home I popped the hood (while it was running) and heard a tapping/knocking from under the drivers side valve cover. I pulled the valve cover and started it up and thought I noticed a rocker going faster than the others. It was also spitting out more oil than I believe it should. Needless to say I put the valve cover back on and started it back up and heard the knock again. I revved the motor and the knock subsided for awhile and started back up when I revved it again. I know the 307 isn't the best motor but for right now I need this motor to run so I can get to school and work with no problems. From what others have said and other forums I have read or said it sounds like it can be anything. Bad gas, carbon, loose rocker, lifter, timing gear plastic, piston ring and other stuff. It hasn't really been running to hot but it's been hot here soon maybe that's a factor?
Please let me know what you all think of this. I really need this car to stay running for a few more months before I transplant a new motor in it.
By the Way....I can provide video if needed....
Thanks!
Thanks!
