Last I remember was the night I got pulled over for "Drag Racing" another Cutlass (which was proven false) I left it in 1st a little longer than usual.
you have to expect damage when you play with a car and it's not built for what you are doing
Fox80 said:The fact that you can turn the crank easy is not a bad thing, a worn motor will spin free.
jetsetw31 said:All these suggestions are solid. But here goes a simple trick to determine WHERE your trouble is. Your gonna try the poor mans Stethoscope. Find a long screwdriver, or you can use the tire iron. (lug nut tool in the trunk.)
pontiacgp said:you have to expect damage when you play with a car and it's not built for what you are doing
