I had 2.56 gears on my 88, 3.42 gears made a massive difference in acceleration. Do you drive a lot at highway speeds and I mean 80 mph?
What does your trans shift at, full throttle? It varies a lot, I have seen 3000 to 4200 full throttle. The 4200 rpm shift point would work just fine.
Your not going to see much of a difference in power and torqure installing a Vin 9 cam with a stock 200r4 trans. Stock shift points are too low to take advantage of a Vin 9 cam.
I have a factory 4000+ shift governor, I can send in the mail for next to nothing. I modified 2 like the link above, it puts the shifts at around 5000 RPM. I also staked the small spring by tapping a scew and lock tighting it in and grinding the head in place, like he shows. i never had a spring fly out since staking it, the regular, no performance governor's don't have that issue. You should replace the lock up solenoid and give it fresh fuild when engine is out getting overhauled anyways, perfect time to swap the governor if it shifting at 3000 RPM. Of course the same can be said for a torque converter as well.
